💵Pro Feature
Using a Meta Tracking Pixel with your site is a great way to improve the success of your digital advertisements.
To use Meta Pixel with your site, you will need to get your Meta Pixel from the Meta Business Suite. If you haven't already, follow Facebook's Steps to create a Meta Pixel. Under 'Step 2' of the Pixel setup, you will follow the instructions for the 'Manually add Pixel code to website' option.
Copy the Pixel ID for the Meta Pixel you want to add to your site, then follow the instructions below.
To add Meta Pixel to your site:
1. Go to the Univer.se app and tap on the site you want to add your Meta Pixel to
2. Tap on 'Settings'
3. Tap 'Marketing Integrations'
4. Tap on 'Setup' next to Meta Pixel
5. Paste your Meta Tracking Pixel ID (only Paste your ID, not the entire pixel code), then tap submit.
6. Your setup for Meta Pixel is now complete!
🌟 Keep in mind it can take up to 48 hours for your site to fully connect with Meta Business Suite and for your insights to display properly.
Still having trouble? Reach out to Support in the app or by email at help@univer.se
Want to get a firsthand perspective? Ask the Universe community here. ✌️
