iPhones, iPads, and Mac Devices
Universe works on all iPhones and iPads that are running iOS/iPadOS 14 and later.
Universe for Mac is compatible machines running macOS Big Sur or later.
You'll need to make sure you are on the latest version of macOS to find the Univer.se Mac App in the Apple App Store. You can learn how to update your macOS here.
🌟Univer.se no longer supports iOS 13 for the newest updates. If you are currently using iOS 13 you can continue to Universe Version 3.60.3. However, in order to take advantage of any new Universe updates & features, you will need to update to iOS 14.
You can find out what iOS your device supports here. You can find out what OS version your device is on by following steps here.
