Your billing period will depend on the subscription plan you choose
Monthly Subscription: You will be charged immediately after signing up. Then you will be billed once a month on or around the date you initially began your subscription.
Annual Subscription: This is billed all at once after a trial period (if offered). Then, you will be billed yearly on or around the date your paid subscription began.
🌟 Each site is eligible for one trial (if offered). A site cannot use multiple trials if they are offered.
