Using the Themes Editor, you now have the power to create reusable themes and update the styling of your entire site within seconds.
You can to use themes designed by our in-house design team or create your own. Themes are available to everyone at no charge and we're excited to see what you create with them. The possibilities are endless!
With the new Themes Editor, you now also have the ability to set block and text types throughout your website. You're able to specify if a piece of text is a large title, title, subtitle, paragraph, or caption. While it is not necessary to update existing Text Blocks, updating them with new style types will allow you to easily change them in the future whenever you update your site theme!
Looking to change your theme? Learn how here!
Need more help? Reach out to our Support Team in the Universse App or via email help@univer.se
