Choose how blocks are layered on top of each other
When layering blocks on your Universe site, you may run into the issue where blocks are placed on top of each other and you don't want them to appear in the order they were added. Luckily, changing the order of layered blocks on Universe is super easy! Just quickly tap on the intersection of the Block Stack you want to change the order of and you'll see the Layer Drawer open up.
👉 If you're not seeing a Block in the Block Layer Drawer, make sure you're tapping on the intersection where multiple Blocks meet. Even if a Block is nearby where you're tapping or touching another Block in your Stack you'll only see the Blocks that are overlapping on the Grid Square you selected. Additionally, If you tap and hold on a block in a stack - the Block will be moved to the top layer.
To edit the order:
- Tap on a block intersection (where multiple blocks touch in the same spot)
- Using the handle on the right side of the block (in the layers platter), drag them to their new location in the list
- Save your changes and publish!
