Login to the Universe Web App using Sign in with Apple or email/password.
The Universe Web App allows you to quickly edit the sites that you created with the Web App without downloading the actual Universe app.
⭐️Since the web editor does not support editing all sites at the moment, you're only able to edit sites you created on the web.
You can begin editing your sites by logging into the editor here.
Once you've logged in using your existing account (Sign in with Apple or Email/Password) all of your sites will appear on the dashboard. From there, you're able to tap on a site and edit its contents! Once you're done, be sure to publish your changes!
🌟 If you have any questions about logging in or the web editor, feel free to reach out to the Support Team in the app or at help@univer.se
