To get started with the Group Block:
- Open the Grid Editor to any Page of your Universe site
- Select the Grid Spaces where you want to add the Group Block
- Select the Group Block from the Block Picker.
- You will be dropped into a secondary Grid Editor inside your Group Block.
Add Blocks to your Group Block
Just like in the normal Grid Editor, you can select, style, and customize Blocks from the Block Picker in your Group Blocks.
Change the Background Style of your Group Block
With your Group Block selected, tap the gear icon in the bottom left corner of the Grid Editor.
Wrap up your Group Block Creation
Tap out of the Group Block once you are finished creating your Block. You can now move, copy/paste, or resize your Group Block.
Watch the full video tutorial on the Group Block
Learn more about the Group Block here.
