The Group Block is a powerful new feature that will allow you to create nested blocks that can then be copied and reused throughout your sites.
Save time with Group Block.
Group Block can help you build more complex sites much faster than before. Create, copy/paste, and move collections of Blocks all at once! You no longer need to place individual Blocks one by one on your site!
👉For Example: You want to make an online store with 10 different products, you can use Group Blocks to create your own “Product Block". This Group Block could contain an image using the Photo Block or Gallery Block, a Text Blocks containing a title, a description, and a Sell Block to allow customers to purchase your item. Before the Group Block you have to create and style all these elements one by one. But now, you can create a single Group Block, copy and paste that Block as many times as you want, change the details of each product, and poof....you've got an online store up and running.
To get started with the Group Block head over to the Grid Editor and select the Group Block.
Go further with Group Block:
How do I create a Group Block?
Can I copy and paste a Group Block?
How do I resize a Group Block?
Do changes to a reused Group Block change everywhere?
