To get started with the Grid Block:
- Open the Editor to any Page of your Universe site
- Select the space on the Grid where you want to add a Grid Block
- Select the Grid Block from the Block Picker.
- You will be dropped side your Grid Block in a near yet familiar place.
Add Blocks to your Grid Block
Just like in the normal Grid, you can add new blocks anywhere you like.
Change the Background Style of your Grid Block
You can change the background of the Grid Block just like any other block. With your Grid Block selected, tap the edit icon in the toolbar. You will have the same options of an color, image, or even video background for your new Grid Block.
Wrap up your Grid Block Creation
When you are done with your Grid Block, tap Done in the top right of the Editor or tap anywhere outside of the block. You can now move, copy/paste, or resize your Grid Block just like another Block.
If you want to see more Grid Block action, check out our Youtube video.
Learn more about the Grid Block here.
