You can save time and keep your site consistent across pages by leveraging the power of Text Styles.
Choosing from existing Text Styles
If you don't have time to manually customize the style of your text, you can choose a style from a few preset options. These options will adjust things like the font, font size, and color of your text.
Creating and editing new custom Text Styles
By editing a Text Style, you are able to edit and update all the text nof the same style on your site in one simple process. Just tap Edit next to the Text Style you wish to adjust, and explore all the ways you can customize the text on your site.
🌟 When saving your edits, those updates will be applied to every Text Block on your site that uses that particular Text Style. These changes will also be applied to all future Text Blocks using that style.
Still having trouble? Reach out to Support in the app or by email at help@Universe.
Want to get a firsthand perspective? Ask the Universe community here. ✌️
