Add YouTube videos to your site
The YouTube Block allows you to directly embed content from YouTube right on your site! It's as easy as searching for a video or even pasting the link.
If you need help getting started or adding blocks to your site, check out our getting started with Univer.se resources.
Adding a YouTube Video
To add a YouTube video to the block, simply search for it by video title or channel name.
Tips for Finding the Right Video
You can directly paste a YouTube video URL into the search field of the YouTube Block to link an exact video.
If you're having trouble finding a specific video in the search results, try adding the channel name after the video title (or just paste the video link).
🌟 Note: Be sure to tap the Search button on your keyboard after pasting a video URL, before tapping the blue checkmark to save your changes. This will make sure your video gets saved properly.
