Add videos right from Vimeo!
The Vimeo Block allows you to directly embed content from Vimeo right on your site! It's as easy as searching for a video, or even pasting the link!
If you need help getting started or adding blocks to your site, check out tour getting started with Univer.se resources.
Adding a Vimeo Video
To add a Vimeo video to the block, simply search for it. You can search by video title or creator name.
Tips for Finding the Right Video
You can directly paste a Vimeo video URL into the search field of the Vimeo Block to link an exact video
If you're having trouble finding a specific video in the search results, try adding the creator name after the video title (or just paste the video link).
