When a customer completes a purchase, they will automatically receive an email receipt that provides them with the option to contact you directly. We also recommend providing a contact email on your site for customers to reach you.
🌟 You can add an email to your site in many ways. Check out the Button Block or the Contact Block for other options.
🌟 Universe Pro gives you the ability to create a custom email forward address that you can use for your customers to reach you.
