Make your site pop by adding GIFS!
The Giphy Block allows you to add a gif to your site directly from Giphy! GIFS are super fun animated clips that allow you to take your site to the next level and make it stand out from others.
If you need help getting started or adding blocks to your site, check out our getting started with Univer.se resources.
Adding a GIF from Giphy
You can tap and scroll through the featured gifs when you open the Block settings, or you can search for something different.
Styling
After you've found the perfect GIF, tap the Style section to apply a shape on top of your GIF.
Adding an Action
The Action section of the Giphy Block settings allows you to choose what happens when someone taps or clicks on the GIF you chose.
These options include:
- Another page on your Universe site
- Another website
- An email
- A phone number
👉Yes, GIFs are Royalty Free
