Add some music to your site!
The SoundCloud Block enables you to directly embed music straight from SoundCloud on your site! All you have to do is search for the track or paste the direct link.
If you need help getting started and adding blocks to your site, check out our getting started with Univer.se resources.
Adding a SoundCloud Track
To add a SoundCloud song to the block, simply search for it. You can search by track title or artist name.
Tips for Finding a Specific SoundCloud Track
You can directly paste a SoundCloud song URL into the search field of the SoundCloud Block to link an exact song.
If you're having trouble finding a specific song in the search results, try adding the artist name after the song title (or just paste the SoundCloud link).
You can also add SoundCloud with the Link Block.
