You can add a custom domain at any time!
No plan is required to purchase a custom domain through Universe as a custom domain is a separate annual subscription. If you wish to connect an external domain that you've already purchased through another registrar (i.e. Namecheap, GoDaddy, etc.) a subscription to the Base, Pro or Complete plan is required.
To purchase a custom domain when creating a new site
- When prompted to "Choose a new domain" search for a custom domain
- Review available domain names
- Tap the price of the respective domain to complete your purchase (Note: the price of domains varies by TLD)
To purchase a custom domain on an existing site:
- Choose the site you want the domain to be attached to from Your Sites
- Navigate to Settings
- Select Domain
- Search for a custom domain
- Select the domain you wish
To connect a domain you already own when creating a new site
- Scroll to the bottom and tap Use a domain you already own
- Upgrade to a Base, Pro or Complete Plan
- Select your specific host/registrar and follow the further instructions on the screen
