Invite collaborators to work on your site with you!
Shared Sites allows you to invite collaborators to work on your site.
You can invite as many collaborators as you want from your site settings tab by generating one-time access codes that are valid for 30 days. You can see how invite collaborates here.
Collaborators are able to make changes to your site, add or remove products, manage Sell Block orders, and more. Although collaborators are able to manage your site, they're not able to delete it, remove your access, or change payout information.
