See who you invited to edit your site using Shared Sites on Universe.
Shared Sites on Universe allows you to add and remove website collaborators at any time.
To see who your Collaborators are:
- Tap the Settings tab in the bottom navigation of the app
- Tap the Shared Sites option
- From here, you're able to view all of your site Collaborators and Pending/Expired Invite Codes
