Choose how blocks are layered on top of each other
When layering blocks on your Universe site, you may run into the issue where blocks are placed on top of each other and you don't want them to appear in the order they were added. Luckily, changing the order of layered blocks on Universe is super easy! Just tap on the Block you want to change the order of to see the Backward and Forward buttons.
To edit the order:
- Tap on a block
- Tap the Backward or Forward button to move the block as you desire
- Save your changes and publish!
