Our color system comes with tons of preset colors and gradients as well as the ability to create your own
Whenever you go to change a color of an element on your website, you'll be presented with our color system. Our Color Picker come with preset gradients and color swatches that you can you consistently across your website if you do not want to use your own colors.
In the color section of the Style tab (on most blocks), you're able to choose your color from the Solids, Gradients, or Custom sections. The solids section is where all of our preset (and named!) colors can be found, and the gradients section contains all of our preset gradients. You can, of course, create your own color palette from the Custom tab to use your own colors on your site!
🌟 If you have any questions, feel free to drop the Support Team a line in the app or at help@onuniverse.com.
