Yes! Universe supports block layering
You can create website experiences like never before using actions you're already comfortable performing inside of the app.
Simply drag a block on top of an existing one!
Need to change the order the blocks appear? No problem! Tap the block, then select “Forward” or “Backward” to change the order and edit the blocks.
