Stack Blocks and build the site of your dreams
Block Layering on Univer.se allows you to place blocks on top of each other to create Block Stacks!
You're now able to stack as many Blocks as you can imagine on top of each other, arrange, and edit them however you like! You can use this new system to create amazing shops, blogs, galleries, or whatever else you can imagine!
👉 Some site elements (such as buttons) may become unusable if another Block (such as Text) is placed on top of it.
After selecting a block that is layered with another block, use the "Forward" and "Backward" buttons to adjust the order of layers in the stack.
⭐️We're so excited to see what you create, so feel free to share your sites with the team!
🌟Make sure you're running at least version 3.40.0 of Universe to use Block Layering
