💵 Pro Subscribers Only
Setting up iCloud+ with your Univer.se site is a great way to upgrade your email! Check out this article from Apple to get started.
To set up iCloud+ email with your custom domain:
1. Open the Univer.se app and go to the site you wish to add these records
2. Go to the site settings
3. Tap 'Domain'
4. Tap 'DNS Records'
5. Tap '+ New Record'
6. Select the record type 'TXT'
7. Under Host Name you will want to enter the '@' symbol
8. Enter the personal TXT record provided during set up under 'Data'. Hit the blue check mark to save your record!
9. Repeat the steps above for the remaining records Apple asks you to add in the setup instructions provided by Apple.
