Adding DNS records can allow you to have more control over your custom domain and opens up options for more third-party integrations.
To add a new DNS record:
1. Open the Univer.se app and go to the site you wish to add these records
2. Go to the site settings
3. Tap 'Domain'
4. Tap 'DNS Records'
5. Tap '+ New Record'
6. You can now add your new DNS record. Select `Type` to choose between CNAME, TXT, MX, A, or Subdomain Redirect Records.
7. Enter all fields required (varies by record type) and tap the blue checkmark to save! If needed, tap '+ New Record' to add more records.
⭐ If you do not see the exact TTL option that you need to add, chose the option closest to it. To learn more about TTL check out this article here.
⭐ To learn more about what type of records you can add check out this article here.
