💵 Pro Subscribers with a Custom Domain Only
TTL is short for 'Time To Live' and is the "expiration date" that is put on a DNS record. The TTL tells the server how long it should keep that record in its cache. The longer the TTL, the longer the information is cached.
⭐ When creating a new DNS record with Univer.se, we recommend using a TTL of 1 hour unless otherwise stated. If we don't offer the TTL requested by your DNS setup instructions, choose the closest option.
