Want to change your standard shipping rate after you created it? No problem! You can return to the Shipping screen in the commerce tab to change the rate.
To change your standard shipping rate:
- Tap Commerce at the bottom of your Dashboard.
- Tap on Shipping.
- Tap on Edit Standard Rate.
- Enter the amount that you want to start charging for shipping. Make sure to tap Set Standard Rate to save your rate!
- Navigate to a product block within the editor and edit the product.
- toggle on Ship this Product.
- When customers add those items to the cart, they will see the new standard shipping rate line item at checkout!
🌟 Changes to your standard shipping rate will not apply retroactively to orders that have already been placed with a standard shipping rate applied.
