Universe is a no code, drag and drop website builder with everything you need to build and run your own website. Universe is designed to be the easiest way to build a website. You can use Universe on iPhone and iPad using our native app or Mac, Windows, Android and more with web.univer.se.
You can use Universe to build link-in-bios, small business websites, art galleries, personal portfolios, ecommerce websites, your own blog, and an infinite number of possibilities. Owning your own personal website allows you to control your corner of the internet just the way you want. You are not limited by what Facebook, Instagram, Etsy or other closed platforms allow you to add to your page. Your website, your rules.
Universe makes handmade customer websites possible with our one of a kind Grid and easy to use Editor. You can design your site existing how you want using Blocks. We have a Block for everything. Universe is the only website builder that lets you build a real custom website, anywhere and publish in minutes.
Learn More:
If you need help getting started or adding blocks to your site, check out the Welcome to Universe article here.
